how/what should i paint my sliders
I'm tellin you guys... that spray I bought will work really nice. You could definitely paint the bottom black, and use the spray for the top half. It will be a lot easier than working w/Herculiner.
metal prep is everything when comes to paint. if you have some tiny oil spots on the tubing, and i'm absolutely sure you have some, no of the paint will stay on. i have spray painted a Sonoran Steel IFS truss and a custom skid plate with Duplicolor spray-on bedliner directly on to the bare steel. touugh as hell.
any metal material, out of the factory, will have some dirt and oil resedue on the surface from the production process. they are impossible to clean up with a piece of rag no matter how hard to wipe it and they are hard to see with naked eyes. being in the printing business, i know it first hand. do a very simple test, get a strip of black eletrical tape, try to stick it on to the tubing, chances are you can peel it off very easily. here is what i did, wipe down the entire area where you need to paint with mineral alcohol, lots of it, to get rid of the excess dirt, and grease. use a propane torch to burn off the alcohol, Ace, Lowe's or Homedepot they all sell the some handheld propane torch. you will see the oil spots when the flame goes through. be patient, nice and slow. try the tape again, you will see the difference.
i met a fella at Pismo Beach this weekend who uses Duplicolor spray-on undercoating, the result is very very good, too.
i prob should have used undercoat instead of the bumper paint but we'll see how it holds up. the duplicolor bedliner stuff is exactly what i got. i need to run by napa and get another can of paint but should have some pics up of the final look tomorrow.
thx again guys
#26
that's what i was planning on doing
thx again guys
thx again guys
The undercoating is generally very soft and if you were to scrape it would easily be marred/removed so if you were going to use it as a primer then that would definately be bad and likewise if you used it on the area you didn't use the Herculiner then light scraping would tend to take it right off and you would be touching up much more .
Under coating is hence the name for under things -fender wells , floorboards etc.
#27
Yup. I sprayed this stuff on my fender wells last week. It is very soft and easy to get off. The can says sound deadening as well as rust protector. I got the cheap stuff.. It was $3.96/can @ Walmart.. ah yeah! Good ol Walmart. They have a lot more automotive stuff than you'd think. Cheap too!
#28
#30
Sound Deadening
Anything you need to cover up do that (electric motor , back side of speaker(should be in enclosureetc.)
Anything you get overspray on will come off with light oil or my favorite - Mineral Spirits hehe
The undercoating won't hurt any brackets or arms for windows etc but wouldn't want to get 3 coats on a window motor or the back of my speakers ( mine would be in enclosures )
ashamsuddin
17
07-22-2024 03:59 AM
kawazx636
10-06-2021 03:03 PM
Toys4parts
09-26-2015 01:56 PM
