How to remove this rivet?
Old 01-18-2016 | 01:45 PM
Rapidrob's Avatar
How do you remove this center pin rivet from the door panel? The vinyl has pulled away from the leading edge and I want to glue it back down?
I know how to remove the window crank and the door latch. Are there any other tricks to pull the panel off?
Thanks.
Old 01-18-2016 | 03:04 PM
donomite49's Avatar
It looks like a push pin. Push the pin in the center and the whole thing will pull out.
I use a Phillips screwdriver to push with.
After its out you push the pin towards the front, not all the way, so you can reset once it's back in place.
Old 01-18-2016 | 03:33 PM
highonpottery's Avatar
X2 you push in the center "pin" of this connector about 1/8-1/4" deep, it clicks IIRC -- and then you can pull out the whole part. They're quite a genius design I think.
Old 01-18-2016 | 04:44 PM
Rapidrob's Avatar
Thanks guy's.
Rapidrob
01-18-2016 01:34 PM
abalagtas
01-17-2016 12:50 PM
Redrezzer
01-12-2016 10:21 AM
wyoming9
01-04-2016 12:43 AM
gilby4runner
12-28-2015 05:48 PM
