How rare are 4.88 factory gears?
Originally Posted by rockota
No... that's normal.
Mine has 4.10 gears like all other 89 4runners.
Remember there was no 31" tire package for 84-89 4runners or 84-88 trucks... and only 4.10 or 4.30 gears...
Originally Posted by Greg_Canada
No.. it's not.
James
#25
Originally Posted by kyle_22r
the rear offsets the pinon to be able to use a thin ring gear compared to aftermarket R&P sets.
Secondly, once I get my 33's mounted(soon my tires, soon) I want to go to 4.88's. I know where I can get a set of factory 4.88 diffs, but would I be getting better diffs if I regeared my 4.56's to 4.88 using yukon gears(or something simaler)?
#26
the ring gear is thinner resulting in a lot less rotating mass. i think if anything, it lets them uses a bigger pinion gear. it appears much larger than the ones used on aftermarket gear sets.
for all purposes, the carrier is the same as a normal V6 carrier, so it should be lockable.
XtraCab
04-12-2020 05:25 AM
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
