How much oil do you go through?
I was using about a quart every oil change (4k miles) before I recently replaced the valve cover gaskets. Now we'll see exactly how much is burned & how much was just falling out thru the valve cover leaks...
Originally Posted by USAtruck6
this is my new dilemma....I go through 6 - 8 quarts every 3km.
I need a major engine rebuild
Is that 3 kilometers????? or three 3 thousand miles??
#25
roughly a quart between changes, but i think its mostly leaked not burnt, couldnt say for shure, other than the underside is fairly greazy
ive had a mechanic tell me my valve cover's were leaking which doesnt surprise me.
#29
I use 1.5 quarts every 3400 miles I found out on my road trip this summer. Personally I find it hard to believe that some burn zero oil. I used to think the same thing until I took extended trips and burned off contaminants. If I do nothing but in town driving it is always full. According to the owner's manual it is normal to burn "some" oil.
#30
Normally, a 1-1.5qts every 3000 miles. Run castrol 10w30 and wix oil filter. I do not believe my 3slow burns oil at all. Even with 230k miles. Rear main seal is leaking.. Tim
#32
I'll add about 2 quarts between oil changes with just about 200k on the engine.
Used to be a bit worse before I changed the O-ring in my distributer shaft and valve cover gaskets. Still have to do the oil pan gasket and rear main seal though.
#33
my old 85 pickup went through about one quarter each gas tank. but the truck actually got a consistent 34 mpg. seriously. i kept a case of cheap oil in the bed, i figured the oil was way cheaper than replacing just about anything of consequence in that engine compartment. ran strong too.
#35
My 95 3.0 uses about 2 quarts every 3000 miles, I think it's the rear main and maybe it burns some too. That's with 154k on it and I have no prior knowledge of how it was treated.
Toyvana
07-29-2015 10:47 PM
yourrealdad
07-29-2015 11:08 AM
