how loud do your valves tick on 22re?
i adjusted my valves to spec but they seem a little loud. i bought the truck non-running so i have no baseline to start from. dosent sound horrible just a bit loud. is that normal? im going to re-adjust them after 100mi. or so
I'm sure one of the experts here will chime in, but I would lean towards a little loud vs. not loud. Or, to say another way, I would rather have the valves set a little on the loose vs. a little too tight. If they are too tight, which I would think would be a little quieter, they would hang open a little, which would lead to burning your valves.
Just my thoughts, whether right or wrong!!!
vmax84
vmax84
Did you adjust them cold or warm and what settings did you use?
I adjusted mine (cold) when I rebuilt the engine a few weeks ago. They were noisy. I drove it like that for about 600 miles and then adjusted them "warm" this past Friday. The noise has totally gone away. I used .008 intake and .011 exhaust. I think the FSM says .012 for the exhaust.
Be sure you don't torque down the valve cover bolts too tight. That will cause louder ticking from over stressing parts. They really only need to be a little more than hand tight
X's 2 on the valve cover bolts; seen it twice now on the 22re; not on my truck, but friend's trucks
that's easy to check though; just losing the bolts while the trucks running. if it goes away, they were to tight...
montanatruck
02-26-2017 07:07 AM
09-04-2015 09:27 AM
