How to fit 35's on a stock 3rd Gen...
#42
Originally Posted by Wildcat_4R
I really like the look of 35s on a stock height suspension. You have a nice looking truck. Have you had any issues with bent steering or blown CVs with the new sized tires?
Steering is fine. No issues. CV's don't normaly blow unless a locker is tossed into the front end. IFS+locker+CV's= Ka-Boom!
Originally Posted by 914runner
Do you work at a Toyota Dealer? I thought I saw your rig out back of the dealer when I was there ther other day.
Yep. I work at Toyota of Gladstone. I'm in the parts detention center there
#43
Looks Like I will buying 35x10.50x15 Tires for my 88 4Runner I Can't stand the Thought of "Lifting" a Truck if you Don't Need to! Why Raise the Center of Gravity of Something you Damn Near Flip all the Time???????? As it is Stock???????? Plus Oem/Stock Look is by Far Cooler then "Jacked Up" Gone Country
#44
Cool. Although don't keep wheelin' with 35's. I have no front diff now. freakin 7.5" front is pretty week. I roasted the ring and pinion a few weeks back doing some very minor wheeling on some rocks. Made some cool sounds but the aftermath took some skillfull work to get the truck out of the gully.
#45
I run bfg 32x11.5"s on 15x8"s on my '94 x-cab. Stock height, rear add-a-leaf. I used to have rubbing, until I reversed my mudflaps off, and then pruned the area around it. I think it's a good compromise between stock and 33x12.5"s. They fit nicely into the body.
#47
Great looking truck man. I wish I was brave enough to try to shoe-horn some 35"ers under my truck.
So, I have just began thinking about running some 33"x10.5" (thanks to this post). Since it seems that many people have done this, on stock toyotas, I have another question. If I run the 33"x10.5", whould I need to run a specific width of 15" rim? I was thinking of doing a 15"x8", but was wondering if this would be too wide and may cause rubbing. I have some rubbing now with my 32"x11.5" and would like to alleviate that. Thanks for any help.
i wish BFG made a 35x10.5
jerusry
10-19-2015 05:28 PM
crashburnoveride
07-10-2015 06:39 AM
