Horn honks when car is not on, then catches on fire
I haven't installed or messed with anything for at least 4 or 5 months. The only thing i can think of is that when i first got the truck i used some of the wire quick connectors instead of soldering my wires. I may just pull the whole dash and redo all of my added wire and fix all of my connections. Hopefully i can pull a fuse and use it for the time being.
#26
may i recomend to just re-wire the horn (seperately and w/2 inline fuses).
should cost about 5bucks for the wire + fuses.
this can help you track down or remove a short.
it may just be in your steering wheel too.
rewire-ing everything will be a pita, but the stereo and horn should be fairly easy.
everytime i install anything (stereo/amp/air-horn etc) i always use
NEW wires
inline fuses
seperate leads into the battery. (stereo/amps for no-chance of buzzing)
sounds to me a clear case of either a wire come loose or a nick in the insulation to and around the blinker+horn.
perhaps a metal foreign particle is wedged inside your steering column.
hope
that
helps
BTW, i also hope your a fellow linux/unix (su-)user
NEW wires
inline fuses
hope
that
helps
#27
idk why
but i read your post and started lmao
i had to replace my horn the other day
the original was a pos
my random 2 pennys
good luck with that though
my random 2 pennys
Bourbonblues
12-15-2017 05:43 PM
