High Compression Numbers
I recently had my head rebuilt on my 22re (had a bad valve), and replaced the head gasket with a stock thickness gasket. Everything is running fine, but I just did a compression test and got 185-190PSI across the board. That is I believe that is about 20 PSI above factory spec. Will that cause any problems?
hmm... as long as each cylinder is in the same area as the others you should be fine.
I would be worried if for say, one was that high and the rest were low.
the1998sr5
27
11-17-2015 09:30 AM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
