Help tranny problem!
hello people,
I really need help. yesterday i open up the transmission oil pan and unblot the valve body off transmission to replace the "kick down cable." i drain all oil out of transmission and drain all oil out of the valve body also. Somehow now i reinstall everything, the transmission is stuck in forward.
The shifter is in parking and is parked, when i'm revving the engine the truck wants to go forward. When i shift into reverse, i step on the gas it will go forward. same with all the other gears. Beside "L" it will not go into L gear. 2 is the lowest i can get to.
SOMEONE HELP ME i have 1993 toyota pickup ext cab 22re with a43d transmission. I dont know what went wrong but it will not go into park, neutral or reverse.
shadowbirdie
07-21-2015 10:38 PM
Iceman4193
07-15-2015 04:48 PM
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
