HELP! SM465 Np205 SBChevy in a '94??
I just bought a '94 toyota 4X4 with 100k. I got a deal because it had broken steering rod. (Recall by toyota-they gave me a free replacement.) Perfect truck except the V6 that was in it is missing! I need the trans out of it for another project. Swapping a smallblock chevy is not really a concern, but I need some advice on transmission options and transfer cases. I have a tried and true SM465 4X4 tranny that I love. I would like to use it if possible. I can fab the crossmember to match on that. Anyboby out there running this setup? What transfer case would be best? I have a NP205 paired with the SM465. I also have a 21spl gear driven toy 4cyl transfer case and a 23spl chain driven case from a V6. I am assuming I'll have to do custom driveshafts. My main question is WILL THE NP205 DRIVESHART LINE UP WITH THE OFFSET ON THE TOY FRONT DIFF?? Any suggestions will be appreciated. I may be overlooking the obvious! Going to measure and test fit the engine this weekend (1st of Sept.)
Thanks in advance
Thanks in advance
toyota transfer case instead with sm465
Anybody know of an adapter to use a toyota gear driven transfer case with the sm465 gm granny gear 4 speed?
Dirt Diggler
18
12-14-2013 09:31 AM
