help me PLEASE?
If it's anything like my '90 truck you'll see how it comes off once you remove the interior door panel and look at the back side of the handle mechanism. The little plastic clips that connect the control rods can be tricky. Don't force them 'cause they'll break. I hope that helps.
The hard part is removing the window crank. Just get a rag and slip it between the crank and the door pannel and then jiggle it up fairly firmly. There is a retaining pin that needs to be dislodged in order to remove the crank handle. Everything else is pretty easy. The inner door handle bezzle slides FORWARD to get it out.
