HELP! Lost all power in engine. Timing chain?
Old 10-23-2015 | 03:57 PM
hexrain's Avatar
94 22re 2wd
Replaced timing chain 6000 miles ago. Head gasket 3000 miles ago.
Was driving home from work and got about 2 miles from the house when all the sudden I lost all engine power. wouldn't start at first but then i got it to start but sounds super clunky. was thinking timing chain so i didnt want to try and run it with the clunkyness happening so as not to break things. where should i start to naroow it down. like i said the first thing that comes to mind is timing chain slipping teeth, but i an intermediate level mechanic so help is much appreciated.
Old 10-23-2015 | 04:14 PM
Terrys87's Avatar
Staff
Pull the valve cover and take a look at your chain. If it is still running, I don't think it is your chain but that would be the quickest thing to see if anything is messed up. The clunky sound could be a rocker out of adjustment. With the cover off you should be able to get a quick visual on several things.
Old 10-23-2015 | 04:35 PM
hexrain's Avatar
to say it is "running" is a little much. it turns over when i crank it and begins to run but it is so clunky sounding i hesitate to give it gas and throw a rod. it sounds like it is trying to "run" at like 100 rpms or something.
Old 10-23-2015 | 04:37 PM
hexrain's Avatar
also i should add that i tried to pull codes but it showed nothing.
Old 10-23-2015 | 05:07 PM
hexrain's Avatar
HAHAHAHA. Im sorry guys! I figured it out. Feel really dumb. I was out of gas... Don't chug 3 beers after work when your tank is on E and you really want to get home...
Old 10-23-2015 | 05:09 PM
hexrain's Avatar
thanks Terrys87 for the quick response... you can delete this thread. might be good to save me the embarrassment when i have a real problem in the future.
Old 10-23-2015 | 06:31 PM
anndel's Avatar
At least you figured this one out. Now we know a Yota has to run on gasoline
Old 10-23-2015 | 06:36 PM
scope103's Avatar
Originally Posted by hexrain
... might be good to save me the embarrassment when i have a real problem ...
Actually, it will make people think you're honest and will report back accurately. Folks on this site respond positively to that.
Old 10-24-2015 | 01:38 PM
Terrys87's Avatar
Staff
We all make mistakes. I found out that you have to have the computer connected for a truck to run, coil wire hooked up for ignition, AFM wiring connected for the air system. I am sure there are few other things I have learned as well the hard way. Congrats on getting things figured out.
Old 10-25-2015 | 08:29 PM
nordicwargod's Avatar
This is kinda funny. We could have come up with some wild but educated reasons for this sudden "failure". I wonder how long it would take for some of us "genius's" to guess that you were out of gas.
JNapolitano
11-14-2019 07:46 PM
Phantez
10-30-2015 04:46 AM
trailgoat
08-13-2015 05:54 PM
themightykhoner
08-11-2015 07:37 PM
Dennisx2
08-10-2015 06:48 AM
Quick Reply: HELP! Lost all power in engine. Timing chain?
