Help Identifying this connector
Hi everyone, I’m just finishing up with redoing the head gaskets on my ‘93, and I’ve come down to this one last connection that I can’t for the life of me figure out where it connects. It comes off the same loom as the TPS and injector connectors. It’s a two wire with a green/blue line and a red/black line.
If anyone might be able to identify it would be super appreciated. Cheers!
Is there a plug under the throttle body? Looked at 93 v-6 3.0L engine bay pics and that cable looks like it goes down under the throttle body. Maybe on the intake tube? It can be too far away as the cable it but so long. Good luck.
thanks Joe! That’s what I thought too but I can’t seem to find anything under there that it connects to. I may have to pull the throttle body to see if I missed something under there. Cheers!
The following users liked this post:
JoeS (04-05-2022)
Edited to add description of the wire. If anyone might be able to check their rig when they have a second to see where this goes would be slick. If I can find someone out there with a second Gen I’ll ask if I can look.
Odd. It sure looks like the Knock Sensor PigTail-to-Harness connector. (EB1) Those wire colors should be Black and BRown.
The only GReen wire listed in my EWD is STJ to the Cold Start Injector. http://web.archive.org/web/201411140...ne/97colds.pdf The other lead to the CSI should be B-W.
EDIT: The ECT Sensor should have a connector very similar to the one in your
picture. Its leads should be G-L (Green-Blue) and BR-B (Brown-Black).
JoeS (04-05-2022)
JoeS (04-05-2022)
Do check your wire colors. Take a picture and report back. Don't feel stupid; someone will find this thread someday and might want to know the wire colors, the shape of the connector, etc.
PS You might have to slightly wet (spit) the wire to get the wire color.
here’s a photo, so anyone reading this can have a laugh. This is what happens when you’re not paying close attention!
JoeS (04-06-2022)
Don't forget that this is all archeology; there's no guarantee that the EWD I have is accurate over all 2nd Gens. Or any of them. Or that the wire colors on my truck (I didn't actually check, of course) are the same as anyone else's. Your contribution (as embarrassing as it might or might not be) could help someone someday.
So yours are G-L (Green-Blue) and BR-B (Brown-Black)?
