Help a/c owner hilux 1989
Hi all; I've buyed a complete used kit of Air Conditionining for my HILUX 1989, nont originally equipped with it.
I have studied the Service Manual many times but I cant understand where the COOLING UNIT http://personal.utulsa.edu/~nathan-buchanan/93fsm/airconditioning/3systemco.pdf wire cable can be connected to the CAR wire harness;
Here the pic of the cooling unit wire cable, where I do connect the Plug 1 and the plug 2?
Can anyone send me some pics at nickvandeerpeers@gmail.com
This is a RADIO plug ?
Thank you all the people can help me.
Bye from ITALY
Nick
Bye from ITALY
Nick
it has been less than 24 hours.
Instead of links to Picassa web, try a different free hosting service like:
photobucket
YT members are a visual bunch of folks, they like to see the actual pics, not links
and I tried to tweek the links in your last few pics but they did not work...they just show up as little red 'x's not sure what the deal is.
anyway, give it a little time and the YT bunch usually comes through.
about the radio plug--yes, I am pretty sure that is the radio plug
good luck
photobucket
good luck
Thank you ocdropzone; I have do what you say me; I'm registred on photobucket; here the pics:
whrere is the other connector plug for #1 and #2 ?
Is this only the radio plug? I think yes
If my truck was not originally equipped with A/C, what do I need for the wire clable? I have all the components but I dont know where is the plug of the cooling unit!
Thank you again!
Nick
Thank you again!
Nick
I know nothing about installing A/C but I e-mailed AZ A/c Kits and they sent me two PDF's on how to install their kits which fit the Toyota harness.
Evaporator:
http://www.ackits.com/pdf/16873.pdf
Compressor:
http://www.ackits.com/pdf/2037.pdf
If you have a part you need or a question www.ackits.com can probably help you.
Evaporator:
Compressor:
Thank You NERVO19; I'll try to contack ackits for explainations;
if someone has old pics that show the connection I'll be very happy
Thank at all
Nick
Thank at all
Nick
