Help with 3VZE ignition timing
#25
i found the problem with the knock sensor, it seem the wire came out of connector to the sensor.. i was trying to find a way to route it but it seems the wire is to short, or unless im routing it the wrong way... does anyone know about how long the wire is from the sensor to the connector on the wireing harness,, mine is about 10 - 12 inches
