Headlight Relay Harness
#81
The autopals are pretty nice. I wish I would have done the upgrade sooner. Im runnin the autopal housing with upgraded harness and some Hella 100/80w bulbs and they are amazing!
#82
Got the Autopals installed...took about 15 minutes. I was already running 55/100 bulbs but I figured I'd try the Autopal 'white' 55/100s...only $4 for the 'upgraded' bulbs but I think I know why. More on that later. Bought these crap eBay housings quite a while ago (cheap, figured why not...now I know why not) and they were better than sealed beams but there's no comparison to the Autopals.
Excuse the dirty truck and cloudy turn signals...that will be fixed this weekend.
Fake projectors:
Autopals:
Fake projectors:
Autopals:
About 4 minutes into the test drive I stopped to make some adjustments and POP...driver side bulb exploded. Scared the crap out of me lol. Pretty loud bang.
Compared to:
That was one of the Autopal 'white' 55/100s. I'm not sure if I should try to clean it out or if I should just return it for a replacement. It's worse than it looks and I'm worried the other one will pop soon...my other bulbs are in the glove box until I decide. I'm afraid I won't be able to get it perfectly clean again which will cause a little output loss. What do you think, return the housing for a replacement or try to clean it?
Fake projectors:
Autopals:
Fake projectors:
Autopals:
Compared to:
#83
I would contact the seller and try and see if they can send you a new housing. If not then see if you can clean it or just buy 1 new housing.
It looked great for the time being.
Thats the main reason I replaced the "Autopal" bulbs right when I bought it. You should order the Hella 100/80w bulbs. I bought them and havent had any issues. You can get a set for about $25 shipped
#84
Fake projectors:
Autopals:
Fake projectors:
Autopals:
Compared to:
Fake projectors:
Autopals:
Fake projectors:
Autopals:
Compared to:
I agree that I would not use it. When that thing burst the hot gas/metal spray may have damaged the reflector coating.
FYI: I LOVE my Autopals!!!!! these are such an upgrade from stock and so easy to install that I wouldnt even think of going the projector route.
I still have the bulbs that came with mine but I bought a new set of Sylvania Ultra's on eBay for $25 and LOVE them too! If I wanted any more light I'd probably use some rectangle driving lights (found a pair on eBay for about $24 shipped) and some replacement H3 100watt bulbs. But for now I am SOOOOO happy with my Autopals that I'll keep rockin these!
#85
Looks like the exploding headlight may have been for the better.
I contacted Rishi with Autopal and we worked out a deal...at first he told me to clean it so I sent him a picture. As soon as he saw it he agreed to send a replacement housing.
Going to attempt to clean it and keep it as a spare...I'm thinking compressed air to get most of the powder out and maybe rinsing it out with some simple green. Suggestions?
#86
Hmm not really sure. The hole isnt very big to do much with maybe if you got a small enough shop-vac attachment but then you still have to wipe the inside somehow.
I know that you can put some headlights in a oven to heat up the glue stuff then open it, clean, then reseal it. I did it on my civic when I painted the inside of my headlights gunmetal. Its worth a shot.
#87
#89
#91
#95
#96
Yeah thats what I am using
http://www.4wheelparts.com/Lighting-...n=HLAH83140171
#97
Assembled a headlight relay harness today. I drafted up a quick (don't laugh) schematic and got to work:
All cable is 12awg THHN except for the H4 pigtails...they're 12awg stranded but not THHN rated. I should have taken pics of the process but when I'm in go mode I just go. Here's the final product:
(2) 30A relays
(2) Female H4 pigtails
12awg THHN
Ring terminals for the battery connections
Butt connectors for the H4 pigtails
Male spade terminals for the factory H4 connector
Female spade terminals for the relays
1/2" wire loom
Electrical tape to wrap the loom
If you want to go all out, you could use a male H4 pigtail instead of male spades to plug into the factory H4 connector and relay pigtails instead of female spades to plug into the relays.
I ended up running a dedicated ground back to the battery (zip-tied to the loom every 6") afterwards. I figured with this much effort I might as well run the extra cable. Copper conducts better than steel and I didn't want ANY weak links.
Went for a quick drive tonight but I need to re-aim the housings. Even with the beams all over the place it's amazing how much brighter good halogens are vs. HIDs in halogen housings. One of these days I'll install a projector retrofit like this and go back to HIDs but for now halogen is fine. 55w/100w bulbs by the way.
(2) 30A relays
12awg THHN
1/2" wire loom
...and does your high beam indicator light work with this?
#98
Just in case you missed it.
In case you don't know where to look: http://www.4crawler.com/4x4/CheapTri...s.shtml#SPtoSG
#99
High beam indicator works.
#100
My Roundeyes will come tomorrow and I just now finished building my ugly 12 gauge harness..hopefully post pics when I get them on...
