Headlight issue 1992 Toyota pickup
Hello, I have a 1992 Toyota x-cab 3.0 4x4 and I am having headlight problems, when my switch is on bright I only get dim lights, when I pull the switch back to dim the headlights go out completely but the bright light indicator remains lit, the park lights and interior lights all stay lit up only the headlights go out, I am new to this forum and would appreciate all the info I can get, I have owned several toyotas but never had this problem before! Thanks again!
A simple and thorough thing to do would be individually check headlight fuses and each high beam and low beam filaments on both bulbs.
On post #199 is how I fixed mine and some other info that I found.
Link>>> https://www.yotatech.com/forums/f199...99/index8.html
Just a quick bit of additional diagnostics.
Usually when the contacts are dirty/faulty you can get the high beams to function in flash mode. eg pull the stick backwards past the low beam setting. This only indicates it's not somewhere else in the wiring if it works, if it doesn't it's not very helpfull but something to check.
Well when I pull back on the stick the head lights do come on but I think it's only the dims not the brights, I could be wrong but the headlights do function when I pull back on the switch, my first step was going to be change the switch anyway! So maybe that'll solve my issue!
Yea I remeber when I was a kid almost everyone had an old Toyota of some kind in their yard, now their becoming extinct! I will always own my Toyota, or one just like it! I don't know what it is about it but I guess I'm in love lol!
Aleeex_u
06-05-2016 07:52 PM
Peteyg39@hotmail.com
06-26-2015 09:15 AM
