headgasket...
headgasket...
reading posts and blogs... and my problem sounds similar to many others... a blown headgasket. i see that i need to buy the gasket and a new timing chain... ok. other than that have the head checked... and i may be ok? once again its the 22re 4 cyl.
I saw your other post, sorry dude. First off, since your oil has coolant in it you posssibly have many problems with the whole engine depending on how long the engine has had water in it and how long you ran the truck like that (watery oil doesn't lubricate very good). A tear down and inspection will be needed to say for sure what you'll need.
This would be a good place to buy parts when you get to that stage:
http://www.engnbldr.com/
