Have sway bar link question
The kid I got my 4 runner from cut the sway bag end link and I can't tell if stock 1s will still fit its on 33" can any 1 tell me if they will or if they make exstended 1 thank any anwser will be awesome
Yes it's has a little lift I think about 2.5 to 3" I heat the way it handles on the road with out the sway bar in the rear it's fine in the woods but the road sux
Are you sure it's the lack of a rear sway bar that's causing the handling problem? I twisted off one of the mounting bolts for mine in the process of removing my rear third. Requires removing the gas tank to drill out the bolt, so I've just left the sway bar off. For the life of me I can't tell the difference, even pulling a trailer on a winding canyon road.
I have been without my sway bar for over 2 years now. Drives straight as an arrow on the road with 33s. If you are having handling problems it is probably not the sway bar. Look over the front end, ball joints, tie rods, etc etc. any play in those parts will cause bad handling. How are the shocks? in good order?? all stuff to look at. good luck
coffey50
07-28-2015 10:55 AM
DrZero
18
07-24-2015 11:31 PM
Vargntucson
07-04-2015 12:15 PM
