GForce Chips - Do they work?!?!
Has anyone used these chips and do they work? They sound too good to be true.
http://www.gfchips.com/toyotapickup.aspx
yup; pure junk, and anyone trying to convince you otherwise is full of it
the computer system in these trucks is so basic that there literally is no room for a computer programming upgrade without replacing the computer with new stand-alone systems
it would be like trying to supe up a calculator... why? there's really nothing that's so complicated that you have to improve upon it
"The GForce module installs into your TOYOTA PICKUP's engine bay and is connected via 2 wires that plug into the IAT sensor. "
Junk. Pure junk.
These things do not reprogram anything. They fool the ECU into thinking the air is cooler than it really is. It's funny they show a computer chip. Because all this thing really is is a 10 cent resistor. Same thing can be basically done by turning the screw on the AFM.
Only thing I would ever use is a reprogrammed ECU or drop in chip. And to my knowledge none have been made for the 22re's.
I would also like to add, they have an option to select 1984 as the model year. Did Toyota even put out an EFI into these trucks. I don't think so. I believe 85 was the first year for the 22re.
Junk. Pure junk.
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
A cold T-stat will make it run rich... oops, I mean "use more gas" too...
More gas = more power... 2MK, exactly how chips work...
Napa has a 160 for a 22R. They're the same between a 20/22/22RE ex the rubber o-ring gasket the RE needs...
There was a thread on here...(have link somewhere) about using an adjustable resistor to fool the ECU into thinking that the engine is still cold. It advances timing and adjusts fuel flow, etc. I'll see if I can find it
IAT sensor mod(google it). Nearly identical in principle to the ECT sensor mod. Nothing new. And not ineffective in any way shape or form. They actually DO work, despite popular opinion.
https://www.yotatech.com/forums/f130...ect-mod-75163/
Here's the link that was posted previously.
http://www.midiwall.com/4Runner/ect.html
IIRC, a while back, there was some outfit advertising on here about reprogramming your stock computer. They would send out a neat litle box to securely ship your computer back to them, then they would ship back. I think the place was in Florida, sound familiar to anyone ???
Downey used to provide the service via JET Performance Products™. They would take your ECU and send it to JET for the upgrade then have them send it back to you. The whole process needn't include the middle-man though. As you can contact JET directly for the same results at a price of $399 + shipping.
Here's the link.
http://www.jetchip.com/imports.asp
Toyota HP Gains
Celica 13-14
Celica Turbo 20-22
MR2 13-14
Supra Turbo 23-24
Supra Twin Turbo 28-30
Truck 4cyl. 13-14
Truck V6 15-17
Non Turbo Applications...Complete modified fuel and ignition curves from 1400 RPM through Wide Open Throttle. Low end performance gains and improved throttle response in all RPM ranges. Low octane fuel OK in most 4 cylinder applications, but for best performance recommend 89 or better octane fuels.
Turbo Cars...Reworked fuel and ignition maps, increased boost pressure (+3-4 lbs in most applications) show substantial improvement in the Turbo applications over entire operating range. OK for use with boost controllers and heavily modified applications.
Celica 13-14
Celica Turbo 20-22
MR2 13-14
Supra Turbo 23-24
Truck 4cyl. 13-14
Truck V6 15-17
yes, the HP of the 22re isn't as responsive to tons of money thrown at it as most other motors I spent over 2k on my rebuild and came out with maybe 30-40 more HP (at best) than stock
Exactly. That's why I haven't gotten around to it myself.
And in actually, even their dyno results don't match the supposed HP gains from their products.
For example, they say that you can net between a 15-17 HP gain with the 3VZE V6. But even their dyno chart says they were only able to increase the rear wheel HP from a maximum of 129 to 140. That's +11 HP, NOT +15-17!
http://www.jetchip.com/dyno.asp?folder=Toyota
So, $400 for 11 extra HP. Really worth it?
While it's true that you'll lose some HP through the drivetrain, any HP added at the crank will ultimately be available at the rear wheels. However, the percentage of that HP loss at the rear wheels vs. the HP at the crank is completely unrelated to what the rear wheel HP output actually is and/or how it's measured. How's that you say?
Look at it like this:
The 3VZE makes a maximium of 150 HP at the crank, according to Toyota. On their dyno it made 129 HP at the rear wheels. There's your drivetrain power loss right there, -21 HP via the drivetrain(slighty more at lower rpms). That amount of power loss is going to remain a near constant. So no matter what amount of HP you add at the crank, you'll lose ~21 HP by the time it gets to the rear wheels. What I mean by "a near constant" is that at higher rpms the drivetrain takes less power turn(or rather keep turning). One word, momentum. The same concept applies to why you get better gas milage at highway speeds than during city driving speeds. Or get more torque output with a heavier flywheel. It's not so much that it's easier to turn per say, but that it's harder to stop turning at any given speed. And the higher the rpm, the more momentum is retained, and the harder it is to slow down. Notice in the dyno chart above that at lower rpms the HP gains where only +10 HP. It wasn't until 5000 rpm that +11 HP was achieved. But pay no mind to that though, it's not what's important to what I'm trying to explain here. Just forget I mentioned it.
So a better way to put it, that's alot more easily understood is this:
The drivetrain takes 21 HP to turn at 5000 rpms(150 - 21 = 129 right?). That amount of HP needed to turn the drivetrain at that speed isn't going to change. It's always going to take 21 HP to turn the drivetrain at 5000 rpms. It's not going to take any more or less than that EVER!
To say that you lose such and such % HP via the drivetrain isn't really an accurate statement then. Why? Because that would mean that the drivetrain would need MORE than 21 HP to turn at 5000 rpms if you added HP at the crank. And LESS than 21 HP to turn at 5000 rpms if you subtracted HP at the crank. Now would that make any sense? No it wouldn't, would it?
Like I said, it's ALWAYS going to take 21 HP to turn the drivetrain at 5000 rpms. Though 129 HP is a certain percentage less than 150 HP, that's totally irrelevant.
Bottom line:
Whatever HP you make at the crank minus whatever HP it takes to turn the drivetrain at whichever rpm is whatever rear wheel HP you'll get. It's ALL about whatever HP it takes to turn the drivetrain at whichever rpm. The percentage of HP loss though the drivetrain is truly meaningless. Sure, it exists as an empiricallity. Meaning, IT'S JUST A NUMBER, and it doesn't really tell you anything important in determining crank vs. rear wheel HP.
SO...IF YOU ADD 15-17 HP AT THE CRANK, YOU ADD 15-17 HP AT THE REAR WHEELS. IF YOU ADD 15-17 HP TO 129 HP THAT = 144-146 HP. NOT 140 HP LIKE THE DYNO CHART PROVES! MEANING, THEY OVERSTATED THEIR CLAIMED HP GAIN BY 4-6 HP! SIMPLE AS THAT!
Bottom line:
I hate to disagree with you MudHippy but your logic is not correct. The parasitic loss is partially due to the amount of HP taken to turn the driveline, known as coulomb friction. Which is represented by a constant number when regarding power loss. But you are forgetting about viscous friction where the losses increase nonlinear between 2 parts.
Taken from another site:
So the percentage of drivetrain loss for a factory truck is 120/150=.86
1-0.86=0.14 or a 14% loss
Now taking their number of 140, this would equate to an at crank hp of 163 assuming the same 14% loss and ALL other conditions being exactly the same.
I agree that the cost for the product seems high for the gained HP. But assuming that a truck with 150hp will see the same 21hp loss as say a 1000hp truck with the same driveline is incorrect.
There are 2 basic kinds of friction- coulomb and viscous friction. Coulomb is the typical kind that is commonly known- a fixed amount that exists between 2 dry surfaces in contact (it doesn't have to be "dry", so much as the energy dissipation has the characteristic linear decay). Viscous involves the frictional losses in a fluid under shear. In this case, the losses increase geometrically with relative velocity between 2 parts.
Also bear in mind that simple frictional losses are not necessarily constant if the "normal force" (the load of the parts being pushed together as they move against each other) increase. That is the likely basis for increasing losses as you test a car through its hp range. More torque applied through the drivetrain implies greater load on the frictional areas of the drivetrain, hence the losses increase, as well. Additionally, more hp implies faster moving parts in the drivetrain which implies increased viscous-style losses in the frictional areas of the drivetrain.
Now add on top of that the rate of increase of speed of each component in the drivetrain, and that will have an additional impact via rotational inertia. If the rise in rpm in the test is very fast (whether it is in the engine or the trans gears or the diff or the wheel/tires), some of that hp goes to "losses" in just accelerational rotation in the hardware (as opposed to the car). The way to isolate this effect out of the test (if you were curious of a more engine-oriented reading) would be to test the car at a constant rpm (at multiple points in the powerband) and applying a counter torque load that is just sufficient to cause the rpm to sag at WOT. Naturally, that is a far more time-intensive kind of test and not at all practical for drive-in dyno shop applications.
