Old 03-11-2016, 03:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problems by Symptom
Print Wikipost
Getting Desperate - backfire/popping from intake
Old 11-12-2012 | 07:09 PM
  #61
ThatGuy1295's Avatar
No the backfireing will burn all traces of fuel. And oil and carbon eventually
As far as adjusting valves goes. I dont think its that. Id say valve timing.
Old 11-12-2012 | 07:12 PM
  #62
Or a bent valve. All has been mentioned in this thread. But the valves are difinetly not funtioning properlly.
Old 11-12-2012 | 07:43 PM
  #63
budgetbuilder's Avatar
Thanks for the info Thatguy looks like I'm gonna have to look into those valves a bit more
Old 11-12-2012 | 11:50 PM
  #64
combatcarl's Avatar
Hook up a vacuum gauge, at idle, and while revving the engine. Video the act, and the gauge's behavior. Upload to YouTube or photobucket, then link here. If you're holding a steady 18 in/hg at idle, I think your valves are ok. Does the vacuum gauge needle fluctuate at idle?
'89 22RE 4x4 longbed DLX
Sent from my LG-P505 using YotaTech
Old 11-28-2012 | 09:48 PM
  #65
well i bit the bullet and had it towed to a shop. They had diagnosis within the hour ....flat cam lobe, yup vital22re called it back on the first page!
Mystery solved
truck is fixed
wallet is empty
Thanks to everyone for their input and recommendations.
Old 12-03-2012 | 11:37 AM
  #66
thought i'd post a pic of the cam for those inexperienced (like myself), this will give you an idea of what to look for when you have the valve cover off and are turning the motor over by hand.
culprit was the cyl #3 exhaust valve, as you can imagine the rocker arm was toast too.
Old 12-04-2012 | 01:16 PM
  #67
JohnnyCanuck's Avatar
Well done, thanks for posting the update. With everything you've done, it's going to run like a top for a long time!
Old 12-08-2014 | 05:34 PM
  #68
orig89pckp's Avatar
Originally Posted by jorgs 4x4
im thinking its a valve... i just put in new heads cams valves in my truck 3vze 3.0 v6 drove amazing for about a month then i started getting the same popping sound from the intake i refused to think it could be just that 2 months later after not driving it i took it all apart and the dam cams were warped had flat spots and #1 exhaust lobe was completly rounded out so it wasnt opening the valve, got parts from japanengine.com 800$ an now r junk only 1500 miles on them, i would check there dont doubt it, i ended up spending 500$ more on other stuff trying to solve the problem with no luck!
I have the SAME problem... and after seeing this i can only imagine it is the problem seeing everything else on the truck is new or checked ok. im taking it apart within the next two days and I will see if true
Old 01-22-2015 | 09:20 AM
  #69
Kalihi,HI's Avatar
Wow congratulations budget builder on nailing the problem, I'm sure it feels so good.im looking for some help. I got a 94 3.0 with a bad backfire (or after fire) when decelerating, it's so loud it sounds like a gunshot...I deleted my cat and just got a new walker sound fx muffler (it's what the truck had when I bought it), but I notice some leaking exhaust in my exhaust pipe (rusted holes) leading up to my muffler. Could this cause the backfire? Thank you for any help.
kawazx636
10-06-2021 03:03 PM
LittleUgly
15
01-02-2020 01:30 PM
wberry85
05-17-2016 05:45 PM
mreagen
10-05-2015 04:27 PM
bradahman
10-01-2015 09:24 AM
Quick Reply: Getting Desperate - backfire/popping from intake
