fuel issue on 86 toyota pickup help plzz????
Old 12-15-2011 | 08:04 AM
  #81
roger k's Avatar
back to top
Old 12-15-2011 | 11:42 AM
  #82
roger k's Avatar
back to top
Old 12-15-2011 | 01:41 PM
  #83
Bassmastry101's Avatar
Holy thread revival..
If you can use the positive from the harness and ground it separately then you have a ground issue with the harness...there is a 4 wire connection that comes from the injectors and goes to one of the intake studs..is it grounded? If it is then you have another problem. How about engine grounds? If the electricity can't flow then nothing is going to work.
Old 12-15-2011 | 01:42 PM
  #84
And what happened to mordoc's truck? I read this whole thread and won't know if he figured it out.
Old 12-15-2011 | 03:41 PM
  #85
roger k's Avatar
it is grounded at the intake, the ground wire comes from the ecu and branches out to each injector. ican jump my test light from injector wire back to the ground wire and get a bright light but when i plug my test light into the injector wire and turn the engine over it is dim, im thinking it a bad ground just dont know where to look
Old 12-16-2011 | 03:47 AM
  #86
roger k's Avatar
back to top
Old 12-16-2011 | 04:19 AM
  #87
The break has to either be from the ECU to the injectors or the injectors to the ground. Just run a test wire from your injector long enough so you can hook your test light to it and check the connections at the ECU. There is a link in my signature for an FSM that has a schematic at the end of it if it helps.
Old 12-16-2011 | 04:06 PM
  #88
roger k's Avatar
thanks bassmastry101 yeah i tried going back to the ecu i had a good light there also im thinking the ecu now not grounding it good enough when i turn it over
Crazychris1871
06-27-2016 10:38 AM
Aleeex_u
06-05-2016 06:52 PM
Gamble_STi
06-27-2015 07:54 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
94hiluxZE
06-22-2015 10:42 AM
Quick Reply: fuel issue on 86 toyota pickup help plzz????
