Front wheel wobble
i have a 88 yota 4x4 with the v6 3.0L my truck has been doing the same thing, not wobbling but it makes a noise when i let of the gas or go to brake it sounds like a bad chain draggin and like a bad vibration feeling. and i just found out today my cv is bad in the driver side so that was my problem
To the original poster: I had bad front bearings and I did the "wobble check" by pushing/pulling on the tire while it was jacked up and never did get any indication they were bad. After doing that a few times I got tired of wondering (truck is a 1990 and i've only had it a year - previous owner did zero maint.) so I pulled it apart and found very worn bearings! They didn't make hardly any noise either which also suprised me.
I also agree with jtcessna, sounds similar to a bad CV joint, although I don't think that would cause a visual wobble, I think that is just a slightly oblong shaped tire and you haven't noticed it before.
My quick thougts any how...
Thanks for the help.
Well the bearings could be making noise or the CV shaft, or... I don't know mine makes noise everywhere!
You said you had your tire balance checked, do you have confidence in the shop that checked it? Of course if the tire were out of balance you should be able to feel it... hmm...
I'd certainly check out those bearings and check the CV boot, bad CVs will usually click too and you haven't hear that right?... hmm...
#25
did the alignment mechanic not shake the front end down before he aligned it? or did he just take your money and set the toe. check the hub assembly. the bolts holding the rotor to the hub can come loose on the unfortunate occasion.
#26
Umm my dad is vw mechanic, and he aligned it for me. But he knows a lot about cars. He checked it out before I toreit down to check the bearings. Turned out it was my new brake pads rattling! Looks like I forgot to put the anti rattle pin in. God silly mistake. Thanks for all the input everyone.
#27
good man. sometimes its the stupid sh** that burns the mind, glad it was only that. wasn't trying to be a jack ass man, just wonderin about the alignment situation. your dad would definitely have to know a lot about cars to be a vw mechanic.
#29
yes he does know a lot about cars. Just not 4x4 trucks haha.We did the toe in at 1/8th of an inch.. Was that ok?
#30
hey new to yotatech and toyotas too. i have a 86 4runner when i'm parked my tire is toed in some itmes i was wondering if that would have to do with the pitman arm and idler arm as well as bearings. i got a saftey inspection and they told me i had play in the idler arm and pitman arm and my bearings it also makes a sound like the tires are screeching when i go over bumbs on paved road.
#31
idler arm pitman arm and front wheel bearings
i just bought a 86 4runner and i was wondering my front wheel when parked sits toed in. i got a saftey inspection and they told me my idler arm and pitman arm and wheel bearings in the front have play.would that cause my wheels to sit funny.it also makes a sound like the tires are screeching when i go over bumbs on paved surfaces.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
lfcarrion3
07-18-2015 04:05 PM
skoti89
07-06-2015 07:45 PM
