Front Suspension beef-up question - 2WD
I want to stiffen-up the suspension on my '94 2WD pickup. Are the stock torsion rods adjustable? Anyone make stiffer replacements? Will air shocks or similar help out? It's a long story but I'm adding weight to the front end and need more spring capacity.
TIA
TIA
downy makes an aftermarket torsion bar.....http://www.downeyoff-road.com/Suspen...s/1979-95.html
Search around, but yes, you can crank them to dial in more preload or replace with stiffer ones. Another solution would be to install ball joint spacers, which will give you a little more height without increasing the spring rate, so the extra weight will pull it back down to level and you'll still have a comfy ride.
There are several producers of after market tbars. Downey, Sway Away, OME (At least for 4x4), and I think Rancho.Cranking your bars will not stiffen the suspension, it will give you more uptravel and you will probably ride the bumpstops more. Torsion bars are the only way to change the actual stiffness.
im part of the ifs club. woo. (the sas guys are just tryin to make themselves feel better about dumpin a bunch of money to get what we can get for half the price and still maintain good road drivability.) ifs for life. yea yeaa
IFS is like the semi hot chick thats loves you and treats you great, but can't do everything that good.
SFA is the uber hot chick who is expensive, knows how to work it and every guy wants her.
wow im bored..
wow im bored..
06-01-2021 01:51 PM
09-04-2015 09:27 AM
Vargntucson
07-04-2015 12:15 PM
