Frame Rot Repair
Thanks terry for an older, cheaper truck it is definately a head turner i see jeeps all day long but very very rarely do i see a toy of mines era in decent shape
I had nowhere near that amount of rot, but in the front passenger side cab mount area I had a funky little hole show up when I was cleaning the rust scale off the frame. I don't have full on pics of my repair, but these three should give you an idea of the outcome.
Yikes:
Plate welded in and welds ground down. Don't want it noticeable that there was anything done to the frame:
Undercoat:
Yikes:
Undercoat:
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Except maybe this.
cab removal:
mark all connections and unplug all electrical
mark and unconnect brake lines (also check under the cab floor for various lines)
drain, remove radiator
undo the steering joint
unbolt the cab,
--reinspect everything because you will forget something
lift the cab off
unbolt the cab,
lift the cab off
Okay so here's an update. I pulled the bed and the cab and got the frame inside. Fortunately the rear crossmember did a great job at stopping the rust from migrating forward. I'll have some better pics once I get a few lights fixed in the shop.
Also the cab came off with almost no problems d&^%&* f&*%&^ alternator wiring how did I miss you on my walk around.
#25
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
1 Post
This is the only truly bad spot on my frame. Right where the passenger-side leaf hanger used to be. I just bought 2 3' lengths of 2.75" wide 3/16ths sheet to do the undersides of the frame rails on both sides in this area. Thankfully someone at some other point in some replated the inner sides on both rails already.
Oddly enough, despite 23 years in Ontario, most of the factory paint was still on the frame before I started stripping it to find soft spots and apply a new rust coat. The minor amount of damage I need to repair can probably be chocked up to the fact they don't salt the roads in rural areas.
#26
my advice
rebuild the entire rear end of that frame
I have an 87 xtracab sr5 with a rotten frame, I've patched it many times, and there is almost no origional frame left lol
every season I get a new crack or hole or weak point, it just doesn't end
the amount of time and work i've put into this I could have built an entire frame by now. strangely enough, the frame under the cab is the only part I haven't replaced..
Theres a guy in town I met that built his own frame from the cab back
not only can you design it to last ( and end your rusty frame issues )
but you can customize it, different fuel cell, different location, different length.. hidden machine gun
just use your imagination
#29
Okay so all the body mounts are off, the grinding and surface prep is under way. I plan on doing POR-15 on the whole frame so I have a lot of surface to prep.
Casualties along the way:
3 brake lines from cab to chasis
clutch hydraulic line
front parking brake cable
Again pictures are on the way.
#30
#32
I dont aim to hi jack the thread, but I am kinda in the same boat here.... My frame is shot from the cab back on my 94 regular cab 4x4..... I found a guy with a '87 2x4 Ex cab that the frame is in perfect condition but motor and trans are shot.... said he will take a hundred bucks for it, will the back half of the frame from the 87 work on my 94....
#34
As you can see the structure for the front end is totally different on the 2x4, plus there are no perches for the torsion bar suspension along the inside of the framerail, and the rear crossmember hoop near the last cab mount will be in the wrong place.
The cab might fit, but you will have to move the rear most cab mount from the 2x4 -xtra forward to where a standard cab mount would be. You have to swap crossmembers, too. The good news is the cab should fit, unless there was a size difference in model years from 87 to 94 because there is no difference based on xtra v. standard cab or 2wd v 4wd.
#35
To the OP's problem, I restored a rusted out in-ground storm shelter by patching and it was probably more work than building a new one from scratch. I originally saw about 10-12 small holes but after sandblasting it down to clean metal there were 1000s of holes.
justdifferentials
14
06-11-2017 08:36 PM
indawire
11-29-2015 05:05 AM
djpg2000
09-07-2015 10:36 AM
