frame
YT Community Team
post up the model# off the driver's door vin plate. it's the last line on the decal
YT Community Team
I can try. what's the first 10 characters of the vin? i don't need the whole thing
YT Community Team
There's just too many choices that way.
I'm guessing you have a vehicle that needs a frame.
The factory service manual has detailed measurements for the various frames each year. You can look at 1991 FSM and get your existing frame measurements/diagrams.
As you find potential donors you can look up the specs for that frame and compare. Odds are, some modifications will be needed, but at least you'll know where.
https://www.toyodiy.com/parts/q.html
if you had access to the truck you could look up the frame number that's stamped on the frame, it's generally a different number from the vin.
