Fog light hookup
Old 12-18-2012 | 10:48 AM
matstaley's Avatar
Get a piece of 1 1/2" angle and mount it to the bolt just to the left of your yellow circle in the first pic. Make it long enough to span across to the bolt opposite that one on the other side of the radiator then mount some lights to it shining through the rectangular holes in the front bumper. Thats where mine are and it works perfect. You might have to relocate the license plate down onto the front valance to unblock those holes.
Old 12-18-2012 | 04:04 PM
Green 88's Avatar
Originally Posted by Fierce Legend
Ok I got a few of solinoids laying around. I just hook one of the fat terminals to the battery with a fuse.
The other fat terminal goes to the lights.
The 2 little terminals 1 gets jumped to the battery side larger terminal and the other is ground for the toggle switch correct?
You can use a solenoid if you like. You got the big terminals correct. One of the smaller terminals is for +12V to turn the solenoid on (not a ground). The other small terminal isn't used in your application. The solenoid gets its ground from the mount so make sure you mount it to metal.
ashersullivan88yota
01-18-2022 05:37 PM
4.34runner88
08-11-2018 10:44 AM
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
Quick Reply: Fog light hookup
