First time partial resto paint...
Old 03-08-2021, 03:02 AM
  #41
Damion812's Avatar
Wow! The end product is great. Hey what is that paint gun? I'm going to be getting one this time around. Last full paint job I was using an electric sprayer, kinda like a Wagner. Works good but orange peel like crazy.
Old 03-08-2021, 06:06 AM
  #42
87-4runner's Avatar
thank you
it's a harbor freight gun and compressor
Not the cheapest or most expensive...
It has a couple of tips so I used the bigger one for the epoxy primer
CLEAN surface before primer with the 101 grease and wax remover let it DRY GOOD!!!
2 primer to 1 hardner 1 reducer - 2 coats 10 minutes apart (clean gun) lacquer thinner or the reducer... I bought a gallon and just used it for cleaning.
base coat with smaller tip 4 paint to 1 hardner - 2 coats 10 minutes apart ( clean gun)
clear with smaller tip 4 clear to 1 hardner 1 reducer -- 3 coats 15 minutes apart (clean gun)
I dis connect the air from the gun and let gravity do the work cleaning, by just filling the pot about 1/4 slosh around and pull the trigger... repeat till clear
Then leave some reducer in the pot and hang it up so it doesn't dry out. Dump it and pour on next product, attach air and clear the gun of reducer till you get to whatever your spraying next ( repeat)
Set the gun pressure at #30
take your time and get the right amount of reducer. Pressure, tip adjustment, distance from surface, and speed of spray... overlapping a little with each pass.
you can build a simple DIY paint booth...I didn't and am completely satisfied with the results. Have FUN!!!
the paint shop sells cups for mixing and they have the ratios on the cup... makes it very simple.
my final sanding was with 320 grit before primer
IF I'd have had everything I needed and could have done the repair on the rear quarter panel, I'd be done, and it only took a week to do. Taking my time and enjoying the process.
The following users liked this post:
Damion812 (03-08-2021)
Old 03-09-2021, 04:11 PM
  #43
87-4runner's Avatar
Glued in the windshield trim with this
swampedout (03-18-2021)
Old 03-18-2021, 01:30 PM
  #44
87-4runner's Avatar
Got stripes?
The following 6 users liked this post by 87-4runner:
5 Fists (03-18-2021), maxvp01 (03-18-2021), Melrose 4r (03-18-2021), old87yota (03-19-2021), SomedayJ (03-19-2021), swampedout (03-18-2021) and 1 others liked this post. (Show less...)
Old 03-18-2021, 07:01 PM
  #45
swampedout's Avatar
Nice work!
Old 03-19-2021, 12:03 AM
  #46
SomedayJ's Avatar
It looks very good!
How did you repair the rusty quarter panel?
Old 03-19-2021, 05:21 AM
  #47
87-4runner's Avatar
Originally Posted by SomedayJ
It looks very good!
great question...
I didn't. Who knows how long it will be before I find a donor truck to hack on, so I decided to just paint it and I'll cut out and repair whenever I get the stuff I need.
be like fixing a fender bender wreck...
you can see the rust issue is at the very bottom of the panel in front of and behind the wheel well... the rocker trim covered most of the front issue... if I never fix it is OK with me we're not selling this one anyway and heck I'm 66 years old I'll be lucky to enjoy it for another 10 years
then the grandkids can enjoy it.
The following 3 users liked this post by 87-4runner:
az4x4runner (03-23-2021), SomedayJ (03-19-2021), swampedout (03-19-2021)
Old 03-20-2021, 01:10 PM
  #48
fdp101452's Avatar
Here's hoping you get at least 30 years to enjoy it. Looks great. Great job bringing one of these old rigs back to life.
RAD4Runner (03-21-2021)
Old 03-21-2021, 12:09 AM
  #49
RAD4Runner's Avatar
Sexy!
Old 03-21-2021, 07:30 AM
  #50
87-4runner's Avatar
Thanks gents
Old 03-22-2021, 03:56 PM
  #51
87-4runner's Avatar
Fat mat the whole inside of the truck...
The following 2 users liked this post by 87-4runner:
old87yota (03-24-2021), RAD4Runner (03-24-2021)
Old 03-22-2021, 04:00 PM
  #52
87-4runner's Avatar
Using 1/4" plywood for rear side panels, covering them with vinyl from hobby lobby and painting it with the sems napa red to match the rest of the interior.
more pics to come
5 Fists (03-23-2021), old87yota (03-24-2021), SomedayJ (03-23-2021)
Old 03-23-2021, 11:18 AM
  #53
2ToyGuy's Avatar
Looking REAL nice!
Pat☺
Old 03-23-2021, 03:07 PM
  #54
87-4runner's Avatar
Originally Posted by 2ToyGuy
Looking REAL nice!
Pat☺
thanks pat
Here's the vinyl covered plywood ($50 for materials for both sides) with a
3 way POLK AUDIO dxi690... 6X9 ( I bought for $60 for the pair) light works and decided to use the old door to look more oem...
The following 4 users liked this post by 87-4runner:
5 Fists (03-24-2021), az4x4runner (03-23-2021), old87yota (03-24-2021), SomedayJ (03-23-2021)
Old 03-23-2021, 03:39 PM
  #55
az4x4runner's Avatar
Excellent work! Very nice looking 4runner. I am not much of a painter but I sure would love to do my 2nd gen someday.
Old 03-24-2021, 05:01 AM
  #56
de6w6it's Avatar
it looks amazing. hoping to do somethibg similar, read: less nice
i will absolutely reference your posts
Old 03-24-2021, 06:08 AM
  #57
87-4runner's Avatar
Thank you... it's been fun... still is.
Old 03-24-2021, 10:59 AM
  #58
87-4runner's Avatar
Made some custom latch covers out of some rubber plumbing caps...
Old 03-24-2021, 11:00 AM
  #59
87-4runner's Avatar
The finished drivers side...
old87yota (03-28-2021)
Old 03-24-2021, 11:01 AM
  #60
87-4runner's Avatar
Dang it double posted again...rrrrr
5 Fists (03-24-2021), old87yota (03-28-2021), SomedayJ (03-24-2021)
Quick Reply: First time partial resto paint...
