First time partial resto paint...
The following 5 users liked this post by 87-4runner:
az4x4runner (03-23-2021),
Genera_lee (03-29-2021),
RAD4Runner (03-21-2021),
SomedayJ (03-03-2021),
swampedout (03-06-2021)
Doing this in my shop with minimal equipment and cost.
doing it in stages fenders, doors, hood, top... then I'll tackle the rear end, lots of body work on it.
Using shop line products with the 033 white factory code paint.
working on the top now
And cowl
Got about $300 in supplies so far.
I don't have a big enough air compressor to do more than a panel at a time, but it's working out great just lots of masking off and patience.
It's not a show truck so it's not perfect but I don't care.
base coat on top...
I'll shoot the clear in about 15 minutes
3 coats of clear 10 minutes apart
1st coat of clear
And cowl
base coat on top...
1st coat of clear
The following 2 users liked this post by 87-4runner:
It is looking very good!
The following users liked this post:
I'm not sure but I think this needs a little attention:
Nice catch... I'll fix that
went out to look at that and it was just a shadow... the way I took the Pic.
Here's what it looks like
finished with the top!
Finished painting the front of the
Truck
Truck
I'm enjoying doing this and about time I get finished, I'll be good enough to start.
it's not perfect but getting better as I go.
The hood was in terrible shape, lots of dents and dings, creases... I'll get a pristine hood someday and paint it.
I have some orange peel going on because I wasn't reducing the epoxy primer enough and the clear wasn't reduced enough either... too thick/ orange peel, too thin/runs... it's a learning curve.
5 Fists (03-03-2021)
Looking good!
Be sure to get the same number of white coats on each part to ensure even coverage or the primer could show through.
And don’t be afraid to put the clear on heavily. Runs are not as big a deal as with single stage paint.
There will always be a couple “fixes” after the painting is done.
looks really good! mel has some good experience and good results on painting his 4runner, so take note.
i think someday is right, even though you believe it to be shadow, it sure looks like the gutter sealer is totally cracked and should have been removed and resealed. a-pillar leaks are likely based on what it looks like, from personal experience.
Primered right rear quarter panel
2 coats of color, ready for clear...
right rear quarter is finished
SomedayJ (03-04-2021)
Whoever put on the fender flares cut the fender wheel wells , pretty much a hack job. oh well, I like the flares.
the fronts they just trimmed the back edge a little bit.. the rear they cut the whole dang fender ??? Shhhesh
The paint job looks good.
Do you plan to paint the hard top also?
Are you going to install the windshield metal trims back or replace them with the rubber one?
no plans to paint the topper, plans to lightly go over it with a scotch pad
metal trim going back on after considerable cleaning to get the nasty urethane mess the windshield installer did...
I already reinstalled the lower piece.
clips are broke on the pillars and top edge, sooo I'll urethane those back in place and hope no need to remove them for the rest of my life... lol
I'll mask off every place i DON'T want urethane for nice clean lines and install
SomedayJ (03-05-2021)
I really like the stainless hardware look!
