Exhaust leak questions
Old 06-17-2009, 09:35 AM
Junkers88's Avatar
Originally Posted by highonpottery
hijack - same topic, different engine and leak location...what do you guys do about a crack in the exhaust (22re) right AFTER where the doughnut gasket is at (toward the cat)? replace the pipe or attempt welding? i've been trying to find my exhaust leak for a few months and had ruled out the manifold and gasket. replaced the two doughnuts thinking it was there as that's pretty common leak area, but it didn't fix it. was under the truck last week and for some reason looked up at the exhaust from a funky angle and found a crack on the engine-side where the "Y" is at a couple inches past the doughnuts. don't know if its such a good idea to try and weld that as i'm thinking the pipe might be brittle from being so close to the header, and being 16 yrs old.
Both of my rigs had welds right where you are talking about from the previous owners.
Old 06-17-2009, 10:01 AM
bob200587's Avatar
If you run some seafoam through it and watch, you should be able to see the smoke coming through any leaks.
Sounds to me like you need a new exhaust manifold gasket. Check to make sure all of the nuts on the manifold are tight.
Old 06-17-2009, 04:14 PM
toyota4x4907's Avatar
Lol. My '93 had that problem, except by the time I replaced the whole down pipe (manifold to cat) it had cracked all the way in half. It sounded cool...for the first week
I actually drove it with it cracked completely in have for about 4 months because it finally gave away christmas night and it was too cold to work on a vehicle until april ( My mom doesnt have a garage at her house) That was two years ago though and I dont have the '93 anymore..
Old 09-01-2009, 09:50 AM
Stuwy123's Avatar
Anyone have an easy way to locate an exhaust leak?
Old 09-01-2009, 10:21 AM
  #25
Junkers88's Avatar
Yes. https://www.yotatech.com/51163851-post22.html
tj884Rdlx
08-28-2015 12:04 PM
thefishguy77
07-30-2015 10:59 AM
the1998sr5
07-16-2015 06:20 AM
Coreyr384
07-10-2015 11:13 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: Exhaust leak questions
