Engine Temperature
Engine Temperature
Just curious what everyones 86-95 4runners are running for temperature. Ive got a Sunpro gauge hooked up and runs about 250 regularly, only problems is most of the gauges I find, engine temp only goes to 250. Curious if Im running too hot, or if the gauge is malfunctioning. Thanks for the help.
So I should probably mention that my temp gauge does not set itself back to 0. When the truck is off, its actually stops at 200. Could the gauge just be messed up? Maybe the needle has been tampered with?
Yeah LOL sounds like a gauge problem alright. So let me get this straight, even when you first start up with a cold engine your gauge reads 200?
mine fluctuates between 180-210 but can get as hot as 250 for short periods of time.
my dash gauge never moves off of center gauge (if it does move its with an needle with of center) my sending unit is screwed into the block were the block drain should be on the pass side.
I dont want to hijack your thread, but is it normal for a 3.0 auto to start to overheat (by the dummy gauge) after sitting of for a few minutes? Sometimes i'll pull in the drive through and want to eat & it will start to overheat. Especially if you leave it running longer than 10 minutes. Could this be a serious problem that needs to be addressed?... Mine seems to run just below the middle mark everywhere while im driving all the time except after extended period at idle or slow moving traffic.Tim
The sensor and surrounding area get "heat soaked" when it's not flowing water.
So even if my dummy guage reads red hot, its really just fine at that point(as long as i have plenty of coolant of course) & im idling. Thanks for the quick reply dcg9381. Tim
If you're reading normal while the truck is running, you're fine.
It's normal for the gauge to "creep" after you turn it off - especially with the aftermarket gauges. Most of them use standard "GM" sensor which have a lot of brass in them. The brass heat soaks easily.
It's not OK for the truck to run hot at idle. If the gauge runs hot because it's off, it should cool down quickly at idle.
Again, for those with gauge problems, use a laser thermometer to check for hot spots on your engine/radiator. It will tell you the real ambient temperature...also useful for diagnosing sticky brakes etc!
Tim is is not normal for the engine to overheat while idling. Sounds like you need to check the fan clutch.
Seattle_Sign_Guy
07-12-2015 12:38 PM
