Engine noise opinions ( w/ Video )
Old 08-19-2010 | 03:18 PM
KBump's Avatar
1993 4runner 3VZE, 171k, Manual. I am gearing up to swap the Timing belt and water pump next week, I been hearing this "rubbing" noise for some time now and can not find it. I really noticed it after doing the valve cover gaskets. Initially I thought it was the fan rubbing the plastic shroud. or warpped/bad pully on the power steering. Not the case here. Sound is loudest at the bottom front. I am hoping to have the front end took apart and a general idea of what i may in for. I have replaced all belts except timing. The noise gets faster as the engine RPMs increase.
http://www.youtube.com/watch?v=Alm_TZlMFrg
Thanks
Kyle
Old 08-19-2010 | 03:55 PM
BC_4runner's Avatar
90% sure your timing belt is either rubbing on your front plastic cover or the rear metal backing.
Old 08-20-2010 | 05:53 AM
KBump's Avatar
Ill have it done this weekend, man I hope your right!!
Old 08-20-2010 | 07:23 PM
KBump's Avatar
Alright. BC 4Runner,good job..Check this out. Got into the timing belt today. I am seriously shocked that my timing wasn't seriously messed up. I never would have thought that sound was timing belt rub. Sounded metallic to me.. Never the less, I found the tensioner pulley was wasted, wasn't holding any tension. The belt was so loose you could freely spin the #1 pulley up top. The back side of the Timing belt was all ate up. The water pump had been leaking for awhile I guess, I just never saw any puddles. Thank goodness for this forum.. all the weeks of reading and searching made this job a breeze so far. I got it tore down and ready for reassembly in about three hours. Thanks yotatech and good diagnosis again BC!
I still dont see how this dude holds tension on the timing belt.. I mean, its just a single bolt unless i'm missing something..The thing looks new!
Also, I think I kinda sorta mabey should have titles the thread a little different and mabey should have waited till after I had gotten this far to post... Rookie mistake.., sorry :-)
Old 08-21-2010 | 06:14 AM
KBump's Avatar
"I still dont see how this dude holds tension on the timing belt.. I mean, its just a single bolt unless i'm missing something..The thing looks new!"
Ah yes... the hydrolic tension device which looks like a small shock..
Glad I figured that out :-)
Old 08-21-2010 | 04:13 PM
KBump's Avatar
ANyWho... Changed Belt, both pulleys, tensioner,water pump and t stat. Started right up. That noise is still there. ANY other suggestions??
It isn't running to hot now, that's a separate issue tho.
Old 08-21-2010 | 05:20 PM
KBump's Avatar
My timing was retarded... I think the PO had some one jack with it.. set it back to 10-12* and runs fine now..
that rubbing noise still buggin the hell out of me tho.
Old 08-21-2010 | 11:02 PM
BC_4runner's Avatar
Good call on changing out that pulley. Did you double and triple check the timing belt wasnt rubbing on the plastic cover OR the metal backing??
I the 3.4 I swapped into my 4runner sounded identical to that, it turned out that the metal backing got bent a bit and the back edge of the belt was rubbing on it.
Try running it without the front cover for a bit just to see if you can pinpoint the noise
Old 08-21-2010 | 11:04 PM
BC_4runner's Avatar
Also just reading through your posts again it sounds like your tensioner may be wasted...
If you can push it in at all it needs to be replaced. You should have to use a vice to push the rod back in to reset it.
Old 08-22-2010 | 01:11 AM
peow130's Avatar
LOL NICE HORN.
Yeah, x2 on that tensioner dealy.
Old 08-24-2010 | 04:31 PM
KBump's Avatar
Hey fellas, I replaced the tensioner already. T-Belt,both pulleys, water pump. BC I DID NOT see anything that would indicate any rubbing on the plastic or metal backing. HOWEVER, The old belt was chewed up on the back side a little. Any thoughts on the harmonic balancer possibly? I took of the skid plate and rolled under the truck while it was running, all the other pulleys spin straight n true, the bottom has a very slight, i mean very slight wobble. Can video if y'all want..
Thanks for the replies so far.
Old belt
Old 08-24-2010 | 04:38 PM
KBump's Avatar
Originally Posted by peow130
LOL NICE HORN.
A thank ya very much sir , I made them myself out of PVC fittings
http://www.youtube.com/watch?v=msZMb1qAfk4
Old 08-25-2010 | 11:17 AM
KBump's Avatar
Found it... Its the AC compressor and/or AC belt tensioner.
Cut the belt, no more noise..
gibbonsballer10
10-26-2023 08:13 AM
LittleUgly
15
01-02-2020 02:30 PM
Davebarbier
11-03-2015 04:28 PM
4Xtruck
16
09-24-2015 10:38 AM
Mrfobbyaccent
09-10-2015 01:13 PM
