Engine Cleanliness
Engine Cleanliness
This is my '86 4WD pickup. Everyone that sees the truck says I have a problem, but I think it's jealousy. I was wanting to see pictures of everone else's engines all prettied up. Pretty pointless thread.. But I've always been really careful about keeping my engine compartment clean, wanted to see if you guys were the same way... Thanks!
I like to keep mine clean for the simple reason that it makes working on it infinitely nicer. You'll always get dirty working on a car, but there's a difference between dirty hands and three inches of black death caked on your hands afterward.
Here's mine
Here's mine
wow that is an extremely clean engine bay! When i bought mine in Nov. 05 It was fairly clean, but now it has a little orange on the front of it. Dont have any pics right now, maybe later.
I was a little drunk when I painted my block, so I try to keep it coated in mud most of the time to hide it's purple-ness... But here's a picture of it semi-clean. Just used the engine cleaner spray at the car wash.
man, its hard enough keeping the outside clean let alone worry about the engine! i kept my mr2 nice and tidy all around, the limo shop i worked for had all the cleaning goodies!
my runner needs a good engine cleaning, i guess ill have to add that to the 'honey do' list. wait, my honey doesnt care if the engine is clean or not! that was easy!
at least if you guys ever decide to sell your rigs, GASP, you would probably get a higher price than the unwashed masses. they look good, nice work.
lee
lee
what is the proper way to clean the engine compartment, how to keep the electronic stuff safe?
and what stuff to use
i would like to spray mine out, but was afraid to mess something up in there
Yeah, im with you. I've never been a big fan of taking a hose to my engine, but i'm gunna have to this year because I got a ton of salt spray on the drivers side so i figure i might as well do the whole thing
all i do is cover up the alternator the fuse box really good and remove the airfilter stuff a few rags down inside of the intake box then lightly hose down the engine make sure its not hot a little warm is alright then use ether simple green or castrol super clean spray everything real good then scrub a few things if its real bad let it sit for 5-10 mins and then hose it down real good i like to use a leaf blower to speed up the drying process then start then engine and let it warm up
Spotless as usual. No kiddin', the mud actually takes some of the engine grime with it when it comes off. Soaks up the oil pretty good, and has abrasive cleansing properties. I use a garden hose, no problems with electronics yet. I used to get water in my EGR, when it wasn't disabled. That was no big deal, it just wanted to run a little rough till it sucked it clear.
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
