eliminate load sensing proportioning valve?
Old 05-24-2009 | 12:51 PM
  #41
jburner's Avatar
OK, went out to try the brakes one more time and just like that they worked! I bled them again anyway, got some more air out, but man that works like a charm, can't wait to get the proportioning valve installed. Know of any automotive store that sells conversion nipples from NPT to Metric in 3/16"? I don't have a tool for manufacturing brake ends, so I have to use premade lines and adapters.
Old 03-21-2011 | 07:13 PM
  #42
cheverlot's Avatar
I was looking around the local juck yard this weekend and I came across an 86 2wd truck that had a portioning valve under the master cyclinder I was wondering can this be installed on a 1988 4wd truck here is a pic of what is looks like did not take pic of bracket but it has toyota stamped on it
Attached Thumbnails eliminate load sensing proportioning valve?-kgrhqeokpge0vi-1o-ebnyyh-zuiw-_12.jpg
Old 03-21-2011 | 09:59 PM
  #43
dntsdad's Avatar
I took mine out and replaced all the lines with lines from a nonabs truck.
I have the Summit proportioning valve, but its wide open so I am not sure that its doing anything meaningful. Maybe I will need it more when i convert to discs this summer
Blamalam
03-12-2022 08:34 AM
JNapolitano
11-14-2019 08:46 PM
Jcrawl94
10
10-24-2015 05:34 PM
justdifferentials
Just Differentials
09-17-2015 07:14 PM
Poppie51
07-23-2015 06:03 PM
