EGR Valve Gasket?
EGR Valve Gasket?
I'm replacing my EGR valve and I cannot find the gasket in the parts fiche, I have it circled in red, is there even a gasket for that particular section?
The egr valve uses the intake manifold's gasket -- it is an extension of that gasket. In other words, you would need to replace the intake manifold gasket in order to change the egr gasket.
I'd just get some gasket material and cut one out, unless you can find one locally that's made just for that
mine had that gasket as part of the intake plenum to the head gasket. all one piece.
Blamalam
03-12-2022 07:34 AM
