ECU pin trivia
ECU pin trivia
Hey YT,
I was doing some stuff last night on my 1995 22REC (California emissions) 4wd pickup M/T (5 speed manual/standard) and noticed that my Toyota service manual shows a pin at the ECU for STP (stop), but I do not actually have a wire from the harness side that feeds to this pin on the ECU. ECU part number 89661-35850. I have the factory service manuals (3 volume/editions) for this specific year make and model, and typically (as for other pins-wires on this harness), where there isn’t a need for a signal, there will be a blank spot (box with a slash through that pin) on the pin out diagram in the book. This pin out says there should be a wire going to that ecu pin. Now, to my knowledge nothing has been molested in this area of the vehicle by PO’s etc, and it’s entirely possible there doesn’t need to be a wire going to that pin for the given drivetrain. I’m just looking for confirmation from someone with a similar setup (manual, 5 speed, 4wd etc) that there doesn’t need to be a wire feeding to that STP pin on the ecu. My best guess is they have that pin there for different models (A/T) maybe, where the stop signal is needed. Anyway, let me know.. Thanks
I don't have a manual 22RE to compare with yours. My wiring diagram also shows a STP pin for all ECU's regardless of transmission. I am not sure why a manual without any type of traction control device like our old trucks would need a STP signal going to the ECU. My guess, like yours, is that it is simply not needed in the manual transmission. Maybe they removed it for the later trucks?
Ecu pins
I have a '94 22RE automatic transmission. Mine does have a wire (green w/white stripe) going to the STP pin. The A/T needs to know when the brake is pressed so that it can disengage the locking torque converter. If this signal was not present and the wheels were locked up during a stop, it would stall the engine.
I checked mine; 1991 4WD/MT/22RE (federal emissions). It does have the green w/ white STP wire in pin 9 of the 14-pin connector, as indicated in the wiring diagram. Circled below, if I'm reading the diagram correctly.
The following users liked this post:
old87yota (03-25-2022)
STP ecu pin
"Lock-up" is a thing in automatic transmissions. Once at the appropriate speed, the ECM signals the lock-up solenoid, which effectively bypasses the (power-using) torque converter. It has nothing to do with "brakes locking up."
I would think most (all?) vehicles would have the wire, just because it is easier to manufacture one harness and just connect the appropriate parts. But I wouldn't count on it; I'm pretty sure the ECM for a manual transmission is different, so it might have a different pin-out as well.
When I first pulled apart my dash, lo and behold there were the wiring and connector for a clock just plugged into plastic nothing behind a blank. Bought a clock off eBay, plugged it in, and it works like it's always been there.
