Dumb brake line question, not size.
I'm in the process of replacing my rusted out brake lines running to the rear of my 87 xtra cab.
In my haste to remove them I did not pay attention to which line went to which port on the junction up front on the passenger side frame rail.
this guy. (picture is backwards the 3 port is actually the front and the 2 port is the back)
basically from the LSPV which line goes to the forward most spot and which line goes the the other one?
Anyone?.. Real quick and easy. I've gone out to look at my truck to help someone on here out many times.
regular cab, xtra cab, 4runner 84-94 is all the same, just a quick peek for me.
I'm assuming the top line goes to the L shaped one and the bottom line goes to the 3 port one but I just wanna be sure.
Pop on here and use the Change Vehicle to put in your rig. The brake line routing in on the Power Train/Chassis tab and the diagrams may help you out. Ctrl + on your keyboard to make the pic bigger.
Looks like 3 port to the front and 2 port to the rear by the diagram.
http://www.utoyot8.com/Picture.aspx?...ccode=&ppName=
http://www.toyotapartseast.com/Page_...2317,2319,2329
My rig will not help you out.
09-04-2015 09:27 AM
