Driveline vibrations
1 Post
Guys do you have any sugesstions on drive line vibrations I have checked the bushings and they seem fine but you never know I plan on replacing them anyway. The only time it vibrates is when I'm off the gas from going 70 or 80 it vibrates the whole 4runner I was just curious if there is a fix to this please help me out . Thanks guys!
Do you have a lift? Did you correct your pinion angle? If the angle of the u-joint at the tranny is not equal and opposite to the one going into the rear end, you will get a pulsating vibration.
It could be the things listed above too. Or an out of balance tire. A loose tie rod end can cause shimmies at certain speeds. Although if it's related to power on or off, then start with the drivetrain.
please put your info in your sig.. to rule out either half of your drive train.. take out your front shaft from your t case to your front diff.. at the same time unlock your hubs.. as i dont know your setup... if you have ADD and no manual hubs.. just remove the locking plates.. then drive it.. if you still have the problem then u know its not your front shaft, diff, or your CV's.. its a place to start..
hiluxinargentina
09-30-2015 05:51 PM
Odin
09-26-2015 06:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
