Downey intake failed. Installing LC dual row chain and Engnblr Street/RV head
Old 05-27-2008, 09:03 AM
mxridercrf450r's Avatar
I talked to the guys at LC and Ted Stanwood, they say everything sounds fine....i was just paranoid. To answer questions about the front end, its a JC Engineering 2wd & steering kit with a King 2.5" race series coilover. Im currently getting 14" of travel
Old 05-27-2008, 09:04 AM
Originally Posted by cadman
I bought one of these when I still had a 3.0 in my truck and when I saw the plastic elbow and electrical conduit nut I knew this wasn't good. I found a rubber grommet that fit the hole perfectly, then turned, drill and tapped some Delrin rod to replace the part of the elbow that goes into the air cleaner. I milled some wrench flats on the part outside of the air cleaner and screwed in a brass barbed elbow fitting for the hose. Inside, a clevis pin and washer is safety wired to keep the new elbow fitting from coming out. I also used nut retainers and safety wire to bolt on the VAFM. The fitting I made for it also seals that area, unlike the elbow supplied by Downey.
I would forget about welding this thing. I did some machining to it to make it fit and it had lots of small voids in it. The casting is a little on the mediocre side.
I really like that set up. Could I pay you to reproduce these parts?
Old 05-27-2008, 02:29 PM
91Toyota's Avatar
You mean LC engineering...not JC. I looked at there kits and they are spendy. Screw that. Truck looks great though
Old 05-27-2008, 02:51 PM
I typed it correctly, JC. LC sells the Total Chaos kits which are similar, but different. Thanks for the compliment
Old 05-27-2008, 08:02 PM
  #25
cadman's Avatar
I think I still have Delrin rod in that diameter, the grommets & washers. I might have the clevis and elbow. Let me see what I have and I'll send you a PM.
Old 06-01-2008, 09:04 PM
  #26
91Toyota's Avatar
Oh my bad...lol. Still a sweet truck
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
Coreyr384
07-10-2015 11:13 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Downey intake failed. Installing LC dual row chain and Engnblr Street/RV head
