Does a twin stick tcase work without the twin stick?
Shift just normal w/o the interlock pin. Only real gotcha is you have to manually push both rails into 4H, then stab the end of the shifter into the aligned forks on the two rails. Note that I do not have "2H" in this setup with one stick, but some folks have ground down the end of the shifter to allow it to pop out of the 2/4 rail into the H-L rail to affect a single "twin stick" mode. I have dual cases, so automatically have a 2L range with the front case.
ashersullivan88yota
01-18-2022 05:37 PM
jerusry
10-19-2015 05:28 PM
