Dipstick question on newly aquired truck
Old 05-02-2017, 10:32 AM
gsp4life's Avatar
http://m.ebay.com/itm/Toyota-Intake-Manifold-Upper-Plenum-22RE-/132164853601?hash=item1ec5a39f61%3Ag%3AzDAAAOSwvih Y-LIy&_trkparms=pageci%253A6e74cc59-2f65-11e7-be39-74dbd1a0ba42%257Cparentrq%253Aca6da49815b0a7f8f8c9 7a1bfffecc73%257Ciid%253A1
Old 05-02-2017, 10:34 AM
gsp4life's Avatar
I don't think that worked, oops. Well, it's in there. Just search "Toyota 22re intake plenum".
Old 05-02-2017, 05:40 PM
CamTom12's Avatar
Just as a note, check your vacuum hard lines if you plan to use them. I tried to blow air through mine and found they were plugged shut with corrosion or something. I ended up just bypassing with soft lines.
Old 05-02-2017, 11:03 PM
RAD4Runner's Avatar
Originally Posted by coryc85
You are missing the idle up actuator. It threads into the intake right next the cold start injector, and I think that big vac line from the throttle body goes into it, and then other things like the power steering and AC idle up VSV have lines that go to it to get your idle to bump up when it's needed.
Yes.
And heifetz17's Fuel Pressure Regulator Vacuum Switching Valve is missing. Should be connected this way...
