Degreasing tips please?
i use that for cleaning my shower. spray it on and wash it down no elbow grease required ha ha
I've used Simple Green a lot, buy it by the gallon, and it's safe on aluminum. I would be careful with a pressure washer on any kind of seals or moving parts, it can force water past the seals and you know what happens then. Keep your distance with the pressure washer, or just use a garden hose or sprinkler.
#25
Army uses simple green we got that stuff everywere works good to gota let it sit for 10 15 min for it to work the best though .
good idea about the bag and the air filter i always just avoided it as best as possible
think my engines ready for a good scrub down and my transmisson
#28
RX Marine was established in 1996 in Mumbai, India; as chemical manufacturing company catering exclusively to the needs of the marine industry. In a short span of 12 years the company has established itself as one of the leading wholesale suppliers of a wide range of chemicals for - Marine industry internationally - and other local industires and plants. Our client list bears testimony to this. The RXSOL policy has its foundations on two pillars of strength - a continuous investment in research and development to deliver premium quality products and a commitment to service.
Degreaser
Degreaser
#29
When I was in the Corps, we used a chemical called TriChlor. Trichloro-triflouro-ethane. Worked fantastic. Nasty to the environment, but back then, as long as we disposed of it "properly", no problem. We used it in an ultrasonic tank, and a few minutes would clean ANYthing. Including rifles. Took the grease and carbon RIGHT off. It had a give away, though. It would turn the areas with the phosphate finish, the matt-black ones, a nice, bright, white. If you didn't reapply a layer of gun lube to it, the armory types would have a fit. But heck, the rifle was CLEAN!
When I got out, Simple Green came along after a few years. It works pretty well, not as fast, but nearly as effective. I use Simple Green for all kinds of cleaning. Counter tops, laundry, engine grease, you name it. Much more variety to it's capabilities than Trichlor had
I don't use it on my weapons, though.
Have fun, all!
Pat☺
Have fun, all!
Pat☺
kawazx636
10-06-2021 03:03 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
