cv axle issue
cv axle issue
SO, about a month ago I broke a chunk off my cv.. which caused popping and binding on occasion.. i bought new axles, but they havent arrived yet. Last night, the passenger side cv axle bearing carrier let go completely, so this morning i ripped off both axles, and bolted everything else back up.
i promise-- THIS IS TEMPORARY!! the new axles should be here within a week.
But, I want to know for sure that my wheels are not going to fall off!!
I didnt tear down everything, mostly because I did not have a 54mm socket, but it looks to me that it will be ok to drive.. So, I DO have the 54mm nut in place, and of course the caliper holding everything together.
Any advice? Just want to make sure my temporary fix isnt going to cause problems.
You're allright I guess. Barring any accidents involving the tape coming off during a heavy downpour and letting water in there. Then you'll wish you'd done what I did and bought some rubber plugs to hammer in there real tight. Worked good for me for a couple months this summer. Found some that fit snug in those holes at the hardware store for a few $. You may wanna look into that, your call.
Yeah, I did. I put my axles back in there last month though. But it worked fine like that in the mean time with the rubber stoppers in there. I didn't go swimming with the thing or anything like that, it did keep the moisture from driving in the rain out.
You just don't want no dirt or water getting in there and fouling up your hubs, or wheel bearings especially. Other than that it can't harm nothin' driving it like that for awhile.
So 3 months ago I ordered replacement axles- new, with 7 year, 70,000mile axles from alloemcarparts.com... And I got 2 that were too long, and i moved, and 2 weeks passed since they sent the axles when i called, so they told me I was "out of luck" since I was past their 14 day return period...
Do yourself a favor and DO NOT BUY ANYTHING FROM ALLOEMCARPARTS !!!
Luckily, their supplier, CV Unlimited, left a phone number on the invoice...
I called them, and after talking with their tech department, shipping department, supervisors, and finally the owner... they agreed to exchange my axles for the parts they should have sent me in the first place...
I got one new, one rebuilt, which was when i found out you want the rebuilds, not THEIR new design because the rebuilds have a grease cap at the diff end as opposed to being sealed, which makes it so you can change them without taking off either the a-arms or the diff, not to mention, theyre actually toyota parts... so i sent those axles back again, after a week of phone calls, and i paid shipping this time.
A month after that, I find out they sent axles to the wrong address (they had it right twice already-wtf?!) so they sent me a new set... of one new, and one rebuild....
I'd really like my damn truck put back together, but tomorrow i will be sending ONE axle back.. with a picture and description of what they should be sending in return, so hopefully they get it right...
this sucks.
this sucks.
shouldnt you keep the stubb axle (the wheel side) bolted in there? I was under the impression that is what kept the bearings stable in the hub? If i were you i would at a min put back in the stubs and bolt them up
I believe the next generation of IFS, you are supposed to leave the stub axle in as they are not full floaters, but I'm not certain on that.
The bearings go over the spindle and the back of the spindle has a larger flange on it that the bearings bottom out on. The front has the nut that holds them on. The axle just goes to the front hub plate, and has nothing to do with weight/bearings.
Learn something new all the time--i was thinking about my 3rd gen.
not to hijack--but who has ordered axles from CV unlimited? Also, because of the questionable quality of Autozone and other such parts houses--what local stores carry quality parts? O'Reilly, Napa......
I've always had good luck with parts and service from RockAuto.com But I suppose you are always safe to go to the dealership provided you want to shell out the dough for their parts. OEM is always best...but RockAuto's stock seems to be holding up just fine over the years in my various rigs.
was just thinking of something local so if i need to exchange them it is not a problem. Dealership just means crazy prices---just wish there was a local parts house that had quality stuff. O'Reilly out here in Austin has some quality parts (MOOG....etc..) but thier Axles are/is their house brand. So i dont know what i wold be getting. Its more important for me because i am running 35's on IFS!!!!
Most people I've heard on the subject say lifetime warranty Autozone cv's work fine. Go to a junkyard & pick up a spare set & get two new cv sets instead of just one, that way you have brand new cv's as spares & easy exchange for busted ones nearly anywhere U.S.A.
JUST an FYI--NAPA has some really nice axles (if you can get them) for a pretty good price
ATM--ALTROM--sources their axles from the OEM manufacturer but cant put the OEM name on the box--
NMB--they are a very nice axle also, have a softer boot and look like a nice quality axle. But if you buy a pair--have them check the axles first to make sure the dust sheild is not bent. Looks like packaging is an issue with those axles.
They both run about $114 a piece--but they are nice
cv unlimited was about 180 or 190 for the pair- i dont remember exactly, it was a long time ago.
BUT, if you add in the $80 bill I just got from them for all the back and forth shipping, I definitely didnt save anything.. those aszholes.
I do alot of mail ordering--but sometimes it nice to walk into the store and say--they need to be warrantied.
"But know you know, and knowing is half the battle"--G.I. Joe........
polo451
13
11-20-2016 07:49 PM
jerusry
10-19-2015 05:28 PM
