Crunchy's flatbed build
I couldn't get a piece of brass behind the sheet metal since I was trying to weld it directly over the 2 inch square tube.
I'm pretty happy with the fix though since itll make it easier to remove the panel and add some turn signals later on.
I'm probably gonna pick up a tig welder and do some practice on the sheet metal. I have some rust I have to repair on another cab.
So today's paint day! I still have more I'd like to add on to the bed like a spare tire carrier setup. But I'm running out of steam and it's getting close to hurricane season here in florida and I gotta free up space in the garage for my girl and I trucks.
so heres a preview of the first couple coats.
4$ a can. Got 5 cans. Used 2 already for the first couple coats
The following users liked this post:
5 Fists (07-27-2020)
26Ga is extremely difficult to weld, especially MIG. In my 15 years in a sheet metal shop I have never seen anyone successfully TIG that light(not counting my welding instructor in apprentice school that welded a pepsi can back together..), nevermind MIG, unless it's just using Everdur to stick it together, but that's not real fuse welding. I would recommend using at least 22Ga, but personally I would probably use 20Ga. I'm also not the greatest welder though lol.
Just my .02 as a tin basher.
Great progress! Looks good painted!
I cant imagine anyone being able to weld something that thin but I am no pro by any means. This is my 4th big welding job. I did some shock mounts for my rear axle and did the chevy 63 swap and a set of step rails.
but since you mentioned working in a body shop I may hot you up for some advice on this cab I have. I've got some rust around the windshield I have to repair. Gonna attempt that myself.
#25
Thanks for the advice man. I gave up trying to weld that and went with some self tap screws. I think I'll end up buying some 1/8th plate and redo the template with that.
Looks good mounted!
#26
Paint dried, rather quickly if I might ad. Used 3 cans for the bed I may....pull it off and just run the other 2 cans for a thick coat.
fuel cell is hooked up and runs, and lights are in.
This is where I'm gonna stop for now.
I do want to add a spare tire carrier, some flooring for my tool box and a spare gas can mount.
but for now shes driveable and looks damn good!
Heres a before and after.
The old rustbucket
I do plan on adding some turn signals but i dig the look!
The old rustbucket
The following 2 users liked this post by Warwagon:
5 Fists (07-27-2020),
swampedout (08-01-2020)
#27
Ready to rock!
What are you doing with the old one? How much to ship it to NM?
#28
Hell if you were in florida you could have the old bed hahaha it's just sitting on top of some old sheet metal so it doesnt fly away in this hurricane we got coming lmao
Sway away bars vs the stock ones
Sits nice and level now. I could probably lower the front a tad bit
#29
Long travel! I want to see more long travel builds, but it depends on what youre gonna do with it.
Stay dry down there! What part of FL are you in?
#30
I started building a front axle for an sas. I eventually want a full rock crawler but realistically I'm going to be in florida another 3-5 years before moving anywhere near heavy rock crawling territory. So I thought a long travel build would be a good middle ground until after I move.
thinking either TC or snatching a blazeland kit. Not quite sure yet.
#31
Well most mud trucks like the straight axle too so you might as well SAS it if thats the direction youre going.
i wish i was still somewhere with mud, loved running my 1st gen in deep mud.....
I dont get the rock crawling fascination, but i respect the builds and skills.
87yotaken
12-29-2016 04:31 PM
Yota Tony
06-03-2007 05:38 PM
