Crankshaft stuck
Crankshaft stuck
Yesterday I was dIrving my 1994 toyota pickup 4x4 to work when all of the sudden it started to make loud knocking noise. I though the chainext had broke and had been flapping around inside but when I got it home and pulled the cover off everything was fine. I went to put the engine in TDC but it won't turn past a certin point so I went the other way and again won't crank past another point. It's almost like somethings stuck in the crankshaft. Has anyone had this problem? ?
Could a spark plug of broken off and jammed a cylinder? Im just guessing here and throwing out ideas. You can get a cheap inspection camera and Harbor freight. So if you pull the plugs you could look inside of the cylinder.
This is from a bike forum but It could happen. What kind of plugs are you running?
http://www.600rr.net/vb/35-maintenan...gine-drop.html
Rickstwowheels
09-10-2015 04:51 AM
