Crank shaft pulley loose
you really should have replaced your front main seal. It was worn flat to the groove in the old balancer. It's a likely weak point and will cause you a leak within the year.
You can do all of this with just removing the fan clutch and the radiator shroud and all your belts.
It's tighter, but you didn't have to remove the radiator.
Cool use of the camera.
Blamalam
03-12-2022 07:34 AM
Dennisx2
08-04-2015 01:26 PM
TJWilly
07-31-2015 02:05 PM
