could someone elaborate on these codes a little more?
i checked my codes.. got this: can someone elaborate on this for me.
code 25
AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--AIRFLOW METER OR MAP SENSOR
--IGNITION
--ECU
code 43
STARTER SIGNAL--NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS 800RPM
--IGNITION SWITCH/CIRCUIT
--ECU
code 25
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--IGNITION
--ECU
code 43
--ECU
code 25
AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR <-- the code related to the fault the ECM is detecting
--INJECTOR FAULT(S)<-- possible source of the fault
--FUEL PRESSURE<-- possible source of the fault
--OXYGEN SENSOR<-- same
--AIRFLOW METER OR MAP SENSOR<-- same
--IGNITION<-- same (you get the picture)
--ECU<- probably NOT the cause of the problem, but still a possiblity
code 43
STARTER SIGNAL--NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS 800RPM <-- once again -- the code that the ECM sees
--IGNITION SWITCH/CIRCUIT<-- possible source of the fault
--ECU<-- ECM (ECU) is typically NOT the cause of the problem
code 25
code 43
Look Here for more info:
file:///C:/Documents%20and%20Settings/mike/Desktop/1993%20FSM.htm
Mike in AR
Originally Posted by regularguy412
You need to work through checking the various possible fault sources for the problem.
Mike in AR
Mike in AR
yeah, you're gonna have to not host that link off of your desktop Mike C:/Documents and settings........ thats your computer
oh sorry,, my bad forgot i had loaded it from there and not from the link
Mike in AR
Try this
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Mike in AR
Try this
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
