Correct Replacement A/C Suction Hose for 1994 Toyota Pickup
Hello,
I am new to this forum and looking for some help. I have a 1994 Toyota pickup with the 2.4L engine and factory A/C. The A/C suction line got a hole in it. I have been trying to find a replacement with no luck. I purchased what was supposed to be a direct replacement from O’Reilly Auto Parts (P/N 55983). But the threaded connection from the hose to the A/C firewall connection was like one size to small. And the alignment pin hole on the other end of the hose that attaches to the compressor was on the opposite side.
So I a trying to find the correct replacement hose, does anyone know where I can get one? A part number as well?
Thank you for any information.
Go to a toyota dealership website and find their parts catalog. They will gave diagrams and parts numbers. And they will tell you if toyota still makes the part or if you have to go aftermarket.
"But the threaded connection from the hose to the A/C firewall connection"
https://oemparts.stonemttoyota.com/p...SABEgIyvfD_BwE
The link above allows you to type your VIN # in the search area to confirm the part is correct.
The following users liked this post:
swampedout (09-07-2020)
ruggers911
08-13-2010 12:27 PM
