Coolant leak
Coolant leak
So i parked my truck today got out and could hear some water dripping, look underneith and sure and behold there was some coolant dripping down the back of my motor. Haven't dug into where exactly it is coming from, but it surely from the very back of the motor, just some drops. Anyone have any ideas?
Do you have a 22R or a 3.0? If you have a 22R, there is a plate on the back of the head that can leak coolant. The heater hoses can also leak around the same place.
Of course the 3.0 also has heater hoses in the back that run into the cab. Lots of places it could be coming from. If you're using the Toyota red coolant it leaves behind a red tell tail residue that makes finding a leak easier.
Here's some pics of my old 3.0 engine to help you see some possiblities:
Try using one of those mirrors on a rod (inspection mirror) to look around in tight places.
#3 or #5 coolant by-pass hose, possibly. Or the heater hoses.
See this thread here. https://www.yotatech.com/forums/f116...-motor-124838/
OK, well i pulled the intake mani off. The coolant by-pass hose is kinked, looks like it would be restricting or even blocking flow for sure. no signs of cracked hoses, plus all the water that came out of the lines when i took the mani off hasn't helped finding this leak.
my major concern was a HG, but the more I think about it, the less I believe that a blown HG is the issue.
Blamalam
03-12-2022 07:34 AM
WellsR
12
07-31-2015 03:27 PM
itzmywife's
07-25-2015 04:55 PM
Avenged
07-09-2015 07:55 AM
