converting 87 2wd to 5VZFE, questions
hi, i have a 87 2wd standard cab short box truck that came with a carbureted 22r, i have since done the 3VZE conversion about 4 years ago, i have 50,000 miles on the conversion and it runs great. however i want more power of course so i just purchased a 5VZFE today with 90k on it and will have a TRD pupercharger installed with it. i was wondering how much more wiring is involved with this swap? i have the complete wiring harnes for the engine including the computer. what else will i need? i heard the starters and fly wheels are different on the 3.4 vs 3.0 is that true? also if anyone has done a conversion like this i would like to hear from you. i would like to have it done by spring, thanks in advance
if you can tackle swapping in a 3VZE into a 22R truck, you're probably won't have any problem with the 3.4.
it'll bolt to the 3VZE motor mounts and transmission, i'm not sure about the flywheel or starter differences.
jon.r
07-11-2015 03:34 PM
crashburnoveride
07-10-2015 06:39 AM
